2072 cubcadet hydro problem
rjlueb
Hi I have a 2072 cub cadet with hydro and it came off the trailer onto black top road going about 35 mph. It stayed on its wheels but does not go a head or backwards since mishap. I used to push it ahead by hand with engine off but it don't budge now. I took back cover off the rear end and don't see anything wrong. when I push hydro makes a little whinning sound but does ont move and does nothing in reverse. does anybody have any suggestions. Thanks
Ouch, would not have been good!
Considering it wont move at all, check for a damaged/stuck brake/s?
Physically check the brakes on the transmission by hand, I hope they are not internal wet discs....
Double check the drive bypass valves are set correctly.
Failing that, it would probably be internal and expensive by the sounds of it.
