Good day, thanks for this support group. I just wanted to share that I was having difficulty with my machine. It cranked fine and I made one pass and it cut off. After that it would not run. Went to your site and discovered several features I was not familiar. Here are the troubleshooting measures I took. Not sure which one actually corrected it.
1. Removed the gas tank and drained the fuel and pulled out the feed line from the tank - there is a fine mesh plastic screen and cleaned this starter fluid.
2. Disassembled the carburetor and took out the main jet and sprayed starter fluid thru it to ensure all of the holes were clear.
3. Did not test the auto-choke, but was not familiar with this wax pin device. Glad that I did not have to order a new one and replace.
After this, I reassembled and it cranked first time. Over all I have been very pleased with the machine - only issue is that the 160cc is on the small side, on occasion the tall fescue lawn with bog it down. I hope this helps.
