dpenniston
- Jul 7, 2014
- 3
I have a 2013 Craftsman 19.5 HP with B&S model 31P677 engine (SN 12 0322 ZD 62769). Bought new over the winter and just started using it this summer. Probably mowed 10 to 15 times. About two weeks ago engine wouldn't crank so charged the battery, no luck. Long story short, after an internet search found that it had flooded the cylinder with fuel. Stopped fuel, pulled the plug and fuel poured out of the cylinder. Cleaned the outside of the carb (not inside), changed the oil, pulled the plug, cranked the engine to blow fuel out, put new plug in, started right up. Seemed to run fine for the day but when parked overnight, same issue, engine wouldn't crank, cylinder flooded.
Suggestions? Full carb cleaning, rebuild, something simple I hope.
