2011 Craftsman 21hp 540cc Platinum XRD Briggs and Stratton OHV engine / Backfire
LLB Tractor-SC
  • / 2011 Craftsman 21hp 540cc Platinum XRD Briggs and Stratton OHV engine / Backfire
Engine has been bullet proof / trouble-free up to now. Sudden loss of power; engine constantly backfiring through carburetor; over-rich exhaust with gas smell. Engine was running fine when this problem occurred. Changed spark plug; no help. Removed air filter, started engine. Constant loud rapid backfiring through carburetor; very loud.
Mower is Craftsman 42" cut model 917.289223. Engine family: 9BSXS.5402VB (Dec 2009 date of mfg). Researching carburetor solenoid as possible problem. Mower out of operation. Any ideas?
First thoughts is a stuck float flooding the engine.
This requires disassembly of the carburettor and a thorough cleaning.
Second thought is a fractured flywheel key.
Cheap & easy to check, pull the cover off and the flywheel retainer there shoud be two rectangular slots, joining together to make a perfect square.
Scottrw
I am having the same problem and was curious what you found to be the problem? Thanks!
Tinkerer200
Remove the valve covers and check push rods.
Walt Conner
