2009 cub cadet ltx 1040
jerrylee
:thumbdown::thumbd The deck has a timing belt which is easily knock out of time causing the blades to hit. Is there any replacement deck or any other solution that could correct this problem?
Thanks for any and all ideas.
:thumbdown::thumbd The deck has a timing belt which is easily knock out of time causing the blades to hit. Is there any replacement deck or any other solution that could correct this problem? Thanks for any and all ideas.
Cub has a fix for this go see a dealer.
You can put a newer deck on that does not have the no good timing belt.
The timed decks are the worse thing ever to be done to a mower.
One thing you can do is put a bigger stronger spring on the idler pulley.
