2008 Hustler Super Z Diesel - To repair or wave the white flag
Buxus
Location
Maryland
I have a 2008 Hustler Super Z, 927335. It has a 32 hp Perkins diesel. It has 700 hours on it, was privately owned, and sat in a garage for years – no rust. Just before I purchased it new hydros were installed. I purchased it to have a pre-emissions high torque beast for cutting tallish grass on my property, about 100 hrs per year.
Shortly after purchasing it, it began to overheat after about 30 minutes. I would of course shut down immediately. Local mechanic replaced thermostat and water pump before I realized that one of the two rear fans was not running. It would blow the fuse repeatedly. I am fairly certain this is why it overheats and wish the mechanic had caught it.
While at a different mechanic’s place awaiting a fan the hydraulic pump failed and now the mowing blades don’t spin. Mechanic says the pump is shot, and there are shards of metal in the hydraulic fluid. He said the metal is more than could come from the scoring he sees on the pump. He said he’s not sure if the shards are old from a pre-hydro replacement issue or are new from an ongoing issue. Both wheel motors currently work great.
The mechanic said a new hydraulic pump is $1500, and it’s about $4k total to replace the pump and flush the system, but that 1. he might not get all the metal out of the fluid (tiny bits left in hydros) which could cause problems, B. there still might be an underlying problem that is undiagnosed so hydraulics might fail again.
I love the mower, and I’d like to get it fixed. I’m not going to be able to get something comparable hours and power wise for under $10k, although it might be a bit newer. On the other hand, am I getting in too deep with too much uncertainty? What do you all think? Thanks!540AA4BD-5961-40C1-86BA-270BCC089A7A_1_102_o.jpeg
