Thanks Mark. You are correct. I removed the belt and it is not the correct one. Not even close. It is 1/2" by 36" . Also the small idler is hard to move. It appears it is rusted where it rides on the larger idler. Next is to clean and lubricate and get a new set of belts. I will post again after that.
