2007 fastrak 17/42
bergejc
I have a problem with sluggish left side transmiision, it is slow to react and even stops periodically. Any suggestions?
Unfimiliar with this machine but it sounds like you have a hydrostatic L & R drive. If only one side is weak, you might have to R & R the pump on that side. See if you can get the numbers off of that pump. It is possibly a Hydro-gear or a Dana, or peerless.
