2007 cub cadet i1046 zero turn tractor
thejr666
Does anyone know if there is a switch in the steering wheel that controls the zero turn?, while mowing i turned to the right and heard and felt a snap in the steering wheel. now the tracor moves but the tires will no go in the same direction. they turn opposite directions. they do it in reverse and forward wont go straight but will do donuts
You are in for a fun time.
Remove the pedals, the lower shroud around the steering stem then raise the floor plate.
Under the plate is the steering gear which has rods that go to the front wheels and to the hydro controls.
If you are a religious man, time to kneel & pray because only heaven knows how to adjust the thing.
Hopefully it will be a broken thing or a pin fallen out.
That floor plate should be removed every so often to clean out the debris that accumulates there.
Som spray lithium grease liberally applied will do wonders.
So after a year i finally fixed the broken gear in the steering box. put things all back together and it moves, and goes backwards and reverse.... but somehow i push forward down and it goes reverse and it is pressure controlled just like forward would be. but reverse goes forward and is one constant speed like reverse would be..... what did i mess up?
