2005 Cub Cadet RZT 50
ccmagee3
I have an electrical issue. It will not start. When I turn the key nothing happens. I replaced the solenoid on the starter. When I tried to start it nothing. If I engage the blades and try to start it I hear a click sound so I figure juice is going from the switch. I replaced the switch anyway to be safe. I do not have a diagram of the wire configuration to the starter so I do not know if I even connected the wires back correctly. I need any help that anyone will give me. Thank you for the help.
Wiring diagrams
Do you have 12v at one of the heavy wires on the solenoid? you should. Also, when the key is in the "start" position, you should have 12v at the small wire on the solenoid
I will check the 12v with key turn today when sun is up. Thank you for the help.
