Export thread
1994 JD 320 Lawn Tractor
#1
Glyn Robinson
Glyn Robinson
Hey
My 320 Lawn Tractor has the FD590V Kawasaki engine.
What make a spark plug on one side flood out with gasoline? It starts running rough and all I have found when I took both plugs out was that one (left side) was flooded with raw gasoline. Thanks
#2
BlazNT
BlazNT
A coil is not firing.
#3
Glyn Robinson
Glyn Robinson
The right side plug is the one giving trouble. so you would say replace that coil?
#4
BlazNT
BlazNT
With an insulated pair of plyers Remove the spark plug wire that you think is working while it is running. If mower dies then replace the other coil.
#5
Glyn Robinson
Glyn Robinson
ok thank you for the advice
#6
Glyn Robinson
Glyn Robinson
I will be replacing the bad coil soon. I will let you know how it turns out. Won't be long before the grass cutting will start.
#7
Glyn Robinson
Glyn Robinson
replaced the suspected bad coil and it runs like new now!
#8
tom3
tom3
Good to hear, that's a real John Deere you have there. And do I see a late 80s Mustang GT in the background? Soon to be the ultimate vintage hot rod some day.
