Honda Tech
Ha ha. Thanks. My wife calls me "obsessed"! lol
No pulley yet. I wanted to make sure that it was running well before fully hooking it up. It's definitely inside the engine.
Well, from as thorough as you have been, I'm at a loss. I assume you replaced the cylinder head gasket. Was it a Kawasaki gasket? I have seen were the wrong head gasket was installed before and the sealing ring ends up exposed to the combustion chamber, allowing the piston to contact it and making a definite knock.
There is no play in the crankshaft at the bearings?? Just grasping for straws...
