1969 john deere 112
Buetowbute
Hello all, I just got a 1969 john deere 112. I was told it was a 1970, but by the charts I've read it looks to be a 1969. Serial number 136667M. Any way he had most of th wiring harness disconnected as he just pull started it. The harness is a mess. Some is missing or has broken wires. I'm wondering if anyone has a harness for sale or can help me out. I am new to these tractors and would like to return it back to how it should be. It is in to good of shape not to fix. Any help would be greatly appreciated as it is currently not running.
D
Deleted member 97405
Guest
hapcoparts.com is a good place to start. Good luck!
JD should have the parts diagrams on line that you can view but only print out one page at a time .
They will have the technical manual which is worth 10 times what they charge for it and from that far back will probably have a better engine service manual that Kohler provide
Good luck
Any old mower is worth two if not 3 modern ones
Well Bert I don't think the Kohler SM would be of any help since according to the serial number it has a Tecumseh HH100 engine. And the service manual I have here only goes to sn 250,000.
