1961 Briggs and Stratton 3HP horizontal shaft engine, Model 80252 - Governor Springs
sihamilton
  • / 1961 Briggs and Stratton 3HP horizontal shaft engine, Model 80252 - Governor Springs
Thank you all for your help. I got the engine running the other day. Everything was working well at idle and throughout the throttle range then all of the sudden it quit. Now have no spark. I replaced the points, condenser, and plug. Gapped the points to 0.020 and the plug to 0.030. I check the magneto and noticed one of the small wires coming out of the coil broke off right at the coil. No way to solder it. It is three leg magneto. Is there an electronic ignition replacement for the 291617 armature-magneto? If so, what is the part number?
V/R,
Steve
