18.5 hp tecumseh gas engine
jdsquire66
White 42" mower with a Tecumseh 18.5 hp engine will fire but not continue running. Carb bowl is clear. Fuel is being pumped to carb.
We are going to need your engine model and spec numbers before we can help you. Without them we have no idea of which Tecumseh engine you have. Help us, help you.
jdsquire66
Model DV490EA
Spec 208033C
DOM 05337LB
FAM 6TPXS.4902AA 490CC
EngineMan
Is that the Tecumseh Engine Number...!
jdsquire66
The information on the label on the motor.
