18.5 Briggs & Strattons Won't Start
Need2learn
Hello I have a strange problem, Today I start my mower with no problem and cut my front yard, I cut off my mower and it WILL NOT start, in fact the motor is turning over very fast now. so this is what I have checked:
I pulled off the valve cover and check the push rods and made sure they were both adjusted fine, turn the engine by hand to see if both valves were moving, adjusted both the valves.
Turn the plug out and made sure the piston was going up and down, checked the spark on the plug and it was getting fire..???
I just don't know whatever to check?? Any suggestion on what could be wrong with this engine?
mechanic mark
Post all numbers from engine data plate, everything. First check oil level on dipstick, make sure it's on full mark, fresh gas in tank, check gas & air filters for replacement. Check fuse between ignition switch & solenoid, lastly raise seat & check seat safety switch & wiring for being pinched.
Need2learn
Thanks but it is getting fire, that shows it is not a switch, I am thinking it is a blown head gaskins
Blown head gasket could be a possible problem, but I am thinking more along the line of dropped valve seat in the head. When you adjusted the valves, did one seem way out of adjustment.
Need2learn
No both seems to be fine, but I went on and adjusted them anyway, if it was drop valve in the head when I turn the motor over both open and closed.. they could both work it if one had dropped in the head right?
The valves would still open and close if the seats came out, but wouldn't seal. Usually when this happens the push rod will drop out or have excess slack. From your description it sounds like a sudden lose of compression. May need to check compression and see what it is. I suspect close to 0. Blown head gasket on those single OHV engines will normally run for some time when the head gasket is going back, but will either smoke severely or blow oil out places it should come from like past the dipstick seal.
Need2learn
Well what you saying makes sense, yes it has been smoking for a while, I plan tomorrow to pull off the head and check the head gasket, and check the valves to see if they are seating....hopefully it just the gasket, and the one the valves has gummed up and cleaning will fix it.
Need2learn
If that what wrong with it, the only fix would be to replace the head?
I have reinstalled the seats back in their recess area and then peened around the edge to hold them in place.
Need2learn
In other words just take out the valves clean or replace and make sure they are seating right..
