151230 98 70774 model #
hlw49
Have a Husqvarna pressure washer model # 020646 00 with this engine that I need parts look up for but find nothing on this engine. Am I missing something.
The engine numbers you posted are not Briggs numbers. Please take a second close look at the engine for more numbers. Should find a model, type and code number.
Most likely location of the model type and code of the engine is on the side of the valve cover, But some of the newer engines have the information laser etched into the mounting flange to the right of the drain plug.
Rivets, the 020646 00 is a Briggs model number for the pressure washer made for Husqvarna. But doesn't show engine info.
That’s what I also found, except that the engine was unavailable.
Scrubcadet10
Moderator
Staff member
From what i gather it uses a new XR950 Briggs...
hlw49
Yes I know all that you guys say is true 151230 is the serial # built 12/30/15. I have looked the engine over and find nothing else etched into the block valve cover or anywhere else. It has one of those codes things you scan but don't have that capability on my phone. Just though one of you might know something I was missing.
If you can take a picture of the QR box and post it, I might be able to scan it.
The engine is a Briggs 130G32-0126-F1.
