Export thread
125b wont start
#1
W
Wildbill7393
I have a Husqvarna 125B blower that has no spark. Changed coil and checked kill switch.
#2
dfbroxy
dfbroxy
Unhook kill wire from coil and secure out of the way. Put cover back on and test for spark again. If you have spark then there is a bare spot in kill wire that is grounding out. If not then you have a bad switch or a defective coil or if your using the plug to test it may be bad.
#3
M
MowLife
Removing the kill wire from the coil will bypass your kill switch. So if you still have no spark it has to be the coil or like mentioned above a bad test plug. If coil was installed correctly with a proper air gap and magnets are secure to the flywheel then you should have spark unless it a faulty coil. If you have spark without the kill wire attached and no spark when hooked up then you have a bad swtch or wire is grounding out. The switch basically completes a ground circuit to the coil to kill the spark.
