11hp to 14.5hp
bnecessary
I am replacing my 11hp to a 14.5hp. I was told it would work... everything matches up. on my 11hp it has 2 wires goin under the flywheel and one yellow wire going to the coil... on the 14.5hp it has the wires form the flywheel I got them hooked up with the old connection... and I figure I could hook up the ones from the carburetor to the lights... but what do I do with that yellow wire that was on the 11hp but not the 14.5
Could you please give us the model numbers off of both engine, so we can see what you are looking at.
