Engine I need to replace my Kawasaki FE400D engine
hebman
My Kawasaki 13Hp FE400D in my 2002 MHGHS let go catastrophically at the weekend and there's now a hole in the casing. I am looking at replacing the motor rather than repair as it will be cheaper.
I have an FE400D-AS04 but I can only seem to find an FE400D-AS00 for sale. Does anyone have any experience in what the differences are?
Alternatively, is there any other engine that I could put in to this particular chassis? I've been told that the chassis are all different for the different power options back in the day andit wouldn't be easy to slot in a briggs and stratton?
Scrubcadet10
Moderator
Staff member
I've Got an FE290, same engine size but different displacement
I think either the Honda GX300 or GX340 is almost a drop in replacement,
Exhaust mounts the same, same shaft size, and electric start optional.
There shouldn't be much difference in as04 and as00, if they are, very minor.
I did see a cylinder block on eBay for $170 new... That's cheap.
Scrubcadet10
Moderator
Staff member
and if you buy a new engine make sure the PTO side shaft rotation is the same,Kawasaki made some CCW and CW
Paul54
Walker have had robin subaru repower kits avail for these models with a little modifcation s/n 95- 20381 to 2011- 112415 , kit # 5011-13 but not sure if still avail? , the other option is briggs vangaurd 14 hp single in similar configuration , ms-ghs 2014 s/n 128422 to 2017 - 144526 but make sure of pto size , length and engine rotation , foot mounting pattern ,plus total hight , & width and muffler location and outlet postion, . Honda repower is possible as well , have seen it done
