Both of my MTD lawnmowers start with the starting fluid but stall after a second of running. I changed the air filters, later just removed them for testing purposes. Checked the spark plugs (just in case), removed the carburetors and cleaned the bowl bolts, one was in pristine conditions, the other was clogged. Changed the gaskets on both bolts and bowls (on one the gaskets were really bad, so I got a rubber gasket at the NAPA autoparts, the fuel resistant one, since I could not find any place to buy the fiber one). Still the same result, starts goes for a sec or so and dies. Any ideas what could be wrong? Any help will be greatly appreciated, thanks.
