Carburetor
The Nikki carb normally has to 2 phillips looking headed screws that hold the fuel bowl on even though they are a JIS screw and a normal phillips can strip the head. The fuel bowl on the Walbro is held on by the fuel solenoid or screw in the bottom of the bowl. The other this the Walbro will have Walbro on the carb body and the Nikki will have Nikki on the carb body.
