Pracher G
- Aug 9, 2019
- Threads
- 1
- 7
First post here.
I have a 1980 model Troy Bilt tiller with the Kohler K161T motor. Great machine!! Earlier this month, I cleaned the carb, and it ran just fine. Right now it will not start. I have replaced points and condenser, and plug. I smell gas fumes when it cranks. It has compression and gas in the tank. When I pull the plug, plug it into the cap and lay it on the block, no spark. What do I check next? This is the 7 HP pull start, no battery.
