summerlane
- Dec 16, 2018
- Threads
- 3
- 8
looking for a good used stator for my 1987 AMT Gator and cannot get it to start. It will turn over but will not fire. I have no spark at the plug
And what is KF 82DX , the engine model number because Kawasaki do not recognise it.
If this is a magneto engine then pull the kill wire from the magneto and see if you have spark when cranking.
seems to be two post going on this issue
Its been 4 years since i worked on the little kawi in the old gator so my memory is a little foggy haha. I do remember the module needs 12 volts power when the key is on. It also has a kill wire to disable spark when key switch is off. The pulse coil charges the capacitors inside the module and best i remember there is a small magnet for top compression stroke to fire the spark. I would make sure power is applied to module and kill wire is not grounded. also a good battery is required to spin the engine fast.
