troy bilt 2 cycle **wont start**
alexio
I recently poured an entire bottle 2.6oz echo Stroke Cycle Engine Oil into my troybilt t35 ec weed eater and then added gasoline to fill it up max.
my weed eater wouldn't start after doing this. I have tried several times but it sound like it will try to run and then it will immediately stop.
reading the label I realized it says to mix entire bottle with 1 gallon of gasoline and not to the weed eater bottle :(
what can I do now to fix it?
please help me
mechanic mark
empty gas & 2 cycle oil from trimmer back into 1 gallon gas can, put fresh gas in can & give it a try. try to remember to put 2 cycle oil into 1 gallon gas can when can is empty then add fresh gas to fill up, the gas & oil will mix well.
i use high test gas & a name brand fuel treatment for outdoor power equipment.
alexio
Thank you sir, I will give that a try today.
Jake8131
Clean all the fuel lines and change out the fuel filter. Make sure you empty the fuel tank.
