Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2018
    Posts
    24
    Location
    North Carolina
    Mower
    Craftsman 2 stroke 25cc string trimmer only runs on 80% choke
    Hello! I am working on a string trimmer for my neighbors, which is a craftsman branded 2 stroke. Seems to be pretty new. When he gave it to me, he said it would start but promptly die. It did that. I changed the fuel out of it, took the carburetor sides off (both the metering and fuel intake diaphragms looked ok, felt silky), and nothing looked too dirty. Cleaned it up with some water, reassembled it and still doesn't run right. Spark plug is fine. When I adjust it to having the choke almost completely on, it will revv up, thought it seems to "hesitate too". It dies at idle though. If I open the choke it idles but bogs down and won't rev up. I don't know what the problem is. I don't suspect the idle screws because they're those kind that can't be adjusted without a special tool and my neighbor doesn't have on as far as I know, nor do I. If it comes down to it, I'll use a Dremel to turn those stupid screws into flatheads. But I don't know what the issue is. Anyone have advice? Thanks!!!
    -Tyler
  2. #2
    Join Date
    Mar 2016
    Posts
    91
    Location
    Florida
    Mower
    lawnboy,honda,stihl
    Re: Craftsman 2 stroke 25cc string trimmer only runs on 80% choke
    Do those stupid screw and open up some.(counterclockwise).Dan
  3. #3
    tom3's Avatar
    Join Date
    Apr 2018
    Posts
    349
    Location
    Ohio
    Mower
    Get a hook and pull the fuel hose out of the gas tank, check the filter and the end of the hose for a crack. I did the dremel deal on my mixture screws and the housing and it really helps to keep it running right to adjust those. Mine are marked H and L for high speed and low. My trimmer has the noisiest muffler of any two stroke yard machine ever.
  4. #4
    1,000 Post Club
    primerbulb120's Avatar
    Join Date
    Nov 2014
    Posts
    1,219
    Location
    Florida
    Mower
    Gravely, Toro, Honda
    Just get the adjustment tool, they're cheap and easy to find online. Dremeling the screws can damage them and prevent them from sealing properly, making the carburetor impossible to adjust.
    Tom, what kind of trimmer do you have?
  5. #5
    Join Date
    Feb 2018
    Posts
    24
    Location
    North Carolina
    Mower
    Quote Originally Posted by TylerFrankel View Post
    -Tyler
    Thanks everyone! I'll try and adjust the screws. Lucky for me, they aren't labeled so I guess I'll just turn them around until it starts working If a dremel will damage it, then.... welll... I'll do it anyway and risk buying a new carburetor. It feels wrong to fuel the EPA and corporate greed.
  6. #6
    Join Date
    Feb 2018
    Posts
    24
    Location
    North Carolina
    Mower
    Quote Originally Posted by tom3 View Post
    I've looked at it, it looks ok to me. It can't be more than 2-3 years old, its very clean and looks new. The carb gaskets are pristine and the EPA screws tells me its not too old
  7. #7
    Join Date
    Nov 2014
    Posts
    10,880
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    The L needle is Longer and is the one closest to the engine
    The H is generally shorter and always closest to the air filter end
    The EPA carbs have a much longer taper section on the needle so generally their initial settings are 2 to 4 turns off sealed
  8. #8
    1,000 Post Club
    Join Date
    Nov 2014
    Posts
    1,219
    Location
    Florida
    Mower
    The EPA doesn't make any money off the tools, in fact they would prefer if you didn't know the tools existed or where to buy them. However, they aren't able to regulate the Chinese manufacturers who mass produce them.
    Don't just mess with the screws randomly. First, begin with the H screw and open it (turn counterclockwise.) Then do the "L" screw the same way if it still hesitates when getting off idle.
  9. #9
    tom3's Avatar
    Join Date
    Apr 2018
    Posts
    349
    Location
    Ohio
    Mower
    Quote Originally Posted by primerbulb120 View Post
    Straight shaft Craftsman 25cc. Red, model 315.794470. All around good machine but not the best for in the neighborhood here. Tried to fit a different muffler on it but couldn't rig one up.
Similar Threads
  1. Craftsman 25cc Weedwacker Grass Line Trimmer Model 316711021
    By Werewolf One in forum Small Engine & Mower Repair
    Last Post: 06-07-2016, 06:47 AM
  2. 2006 Craftsman String Trimmer Runs Great Without Attachment
    By Blaine B. in forum Craftsman Forum
    Last Post: 04-25-2015, 10:57 AM
  3. craftsman 4 stroke weed trimmer
    By kevinhonn in forum Small Engine & Mower Repair
    Last Post: 10-30-2013, 07:08 AM
  4. String Trimmer Not Running in Anything Besides Choke
    By jcsjourney2008 in forum Small Engine & Mower Repair
    Last Post: 08-29-2013, 08:58 PM
  5. feul mix ratio needed for Yard Machine 25cc string trimmer
    By suzi_2011 in forum Mower & Equipment Operation
    Last Post: 06-09-2011, 05:49 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
