Results 1 to 4 of 4
Thread: 3 acres to mow
  1. #1
    Join Date
    Feb 2019
    Posts
    Location
    North Carolina
    Mower
    Looking to Buy :)
    3 acres to mow
    New to this forum and wanted to know what y'all thought about being the best high grade residential zero turn that has a quality make and i am not one who cares about brand just fair quality for the price. New yard is flat and has many trees spread out through out the edges. Looking for recommendations and thoughts on what is solid.
    Sadly the ol craftsman LT2000 cant handle the yard...
  2. #2
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    6,973
    Location
    Missouri
    Mower
    RZ5424
    Re: 3 acres to mow
    Husqvarna then Spartin.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  3. #3
    tom3's Avatar
    Join Date
    Apr 2018
    Posts
    483
    Location
    Ohio
    Mower
    Re: 3 acres to mow
    Lot of us here would like to be able to honestly answer that question but with all the crap out there these days it's tough. Even the old good names are pulling out the quality to raise the bottom line and dupe the unsuspecting buyers. Especially when the search is for residential. Groundskeepers at work use Big Dog and Bobcat equipment that really seem like good machines, but they're getting old and probably out of the price range for most homeowners.
  4. #4
    Join Date
    Nov 2014
    Posts
    11,817
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: 3 acres to mow
    used commercial should cost about the same price and serve you much better.
    Got a few Great Danes in my run and they are really robust machines.
    A used commercial running badly will still be a better bet just as long as you buy it to mow, not admire with a beer in your hand.
    After that look at the standers, they are built for commercial operators but are smaller & cheaper than the equivalent deck sized ZTR.
    I like the JD ZTR's because they are designed well with features like a wrench built into the height control pin.
    Then all of the bolts that need regular checks are the same size as the wrench.
    Bolts in hard to get to places are either captive or have coach heads so they can not turn.
    The exact same looking McCulloch has 8 different sized bolt heads
Similar Threads
  1. Looking for a new mower! 2 acres, up to 7 acres. P-ZT... S125xt?
    By Fizzerpilot in forum Mower & Equipment Buying & Pricing
    Last Post: 09-27-2017, 02:22 PM
  2. Need to mow 14 acres
    By Pete2294 in forum Mower & Equipment Buying & Pricing
    Last Post: 08-26-2013, 10:15 AM
  3. Mow 3 Acres & Plow 100 Yards?
    By KC9WDF in forum Mower & Equipment Buying & Pricing
    Last Post: 05-29-2013, 03:37 PM
  4. $5500 budget 2.5 acres to mow. Which Zero Turn?
    By josh83 in forum Mower & Equipment Buying & Pricing
    Last Post: 07-13-2012, 04:05 PM
  5. Moving to country lot with about 3 acres to mow
    By robertjmaurer in forum Mower & Equipment Buying & Pricing
    Last Post: 05-30-2012, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
