Sounds like your carb is leaking gas into the engine. First is to drain and full the oil and turn the engine by hand to see if everything is still working ok. Not by the blade. Then if you have a fuel shut off turn it off and let it sit overnight and see if any gas has gone into the oil. if not then turn the gas back on and wait overnight and see if gas has gone into the oil. We wait for your answers.
