7394
- Sep 5, 2014
- Threads
- 84
- 4,718
I generally run my tractor 2 or 3 times a week, in the Winter...mostly doing some chansawing in the woods, etc. Whenever I am out in the shop for any length of time, I hook up a trickle charger to the mower battery, and bring the battery to full charge. At least once a week, I start the lawn tractor up, and let it run for several minutes....that way, between keeping the batteries charged, and running the units several times during the Winter, all I have to do is turn the key when I need to use them. I usually get several years out of a battery before they show any signs of wearing out.
The thing I don't like is just running a engine for only several minutes over & over thru winter. Doing that does not give the engine enough time to get a full heat & burn out all the condensation in the crankcase created from the many short runs. I leave mine hibernate.
But I do have them hooked to Battery MINDers* with ambient temp compensators. This will adjust the 'float' rate, higher for winter & lower for summer.
I lost my Harley FatBoy battery to a battery tender. It just ran it dry as a bone. That's when I switched to the temp compensated MINDers* ......
