Hi guys. It looks like I lost the compression release mechanism off the cam of our B&S 19.5 motor and I'm going to swap out the cams and everything else is perfect PLUS the motor runs flawlessly when I get it to start.
So, given that are their any tricks and tips on how best to remove the motor so I can swap the cam. I have a full workshop so tools are not a problem and I would classify myself as above average backyard gearhead. I just know there's always tips/tricks to anything that others have discovered by necessity that might make it easier. In particular is the lower pulley off the crankshaft.
Any suggestions or recommendations are very welcome..... Thanks a ton.john
