Is there a comfortable wrap for a 13" steering wheel ?
Denna
  • / Is there a comfortable wrap for a 13" steering wheel ?
The OEM steering wheel on a Troy Bilt 54" Bronco has a hard, uncomfortable grip similar to a tire.
Can anyone recommend a replacement wrap that doesn't have a tire like texture and won't get hot to the touch ?
7394
Auto Parts have steering wheel wraps that you lace on, it would be too big, but you can cut to your needed size.
As far as not getting hot out in the sun, I don't have any answer for that. But if you park it inside the wheel will be more comfortable & coller, & when yoiu are mowing your hands will be moving on the wheel, so that'll help.
PS: I have also saw some velour wheel wraps that use elastic.
Gets real hot down here so the auto parts stores sell a wheel cover made of reflective foil and insulating foam.
Handy if it is not being used but no good while you are mowing.
Leather gloves, particular golf or driving ones might be the go.
Denna
bertsmobile1 and 7394,
Thanks for your responses.
The DIY wrap looks to be the solution.
