Hi Guys,
I have owned LawnBoys for decades and I recently picked up my third, (because the other two have continued to run for over 20 years), and it needed some TLC.
This is an S19ZPN, SN: G349B0243. Same old story on why the owner wanted only 25 bucks for it. Won't start. Can't fix it, etc.
Well the tank was flushed, new line installed and the carb cleaned and it runs fine now. My issue is the previous owner rigged the Control Arm when the Control Cable broke. I can find numerous cables but it also needs some of the parts at the engine end of the works. In particular, the spring is missing and most likely a few more pieces. Basically if I want to mow with it, I have to shut the fuel valve off and wait for it to starve to a stop. (Choking won't kill it).
I couldn't find a good parts diagram online to point me to what I need to order where the control cable meets the assembly under the tank. Any help would be greatly appreciated. Again, I can find the cable. The handle parts are all there. I need help at the lower end to get it to shut off when I release the control handle.
Thanks in Advance.
Thanks in Advance.
