Nothing comes from factory ideal for every consumer. I find myself always making modifications to products I buy. This rider is no different. So far, I've made 4 changes that were needed.
1st was to add a LED flashing light to the rear of the mower so it will be more noticeable while mowing along the highway.
2nd and third are in the picture below. I added toggle clamps on either side of the engine cover, as the terrain I mow was causing the cover to constantly bounce around and flip open. As you can also see, I added a fire extinguisher below the seat.
Lastly, I placed an industrial zip-tie around the two bolts that are at the left edge of the mower deck to keep them from snagging on my fence. The deck was occasionally catching the fence when I was mowing along it and this quick addition certainly did the trick.
Anyone else make any modifications to improve your mower?
