Agree. If you're going to spend that kind of money, get what you want. The Ferris would probably last me a lifetime. For me, it'd just be for homeowner use to cut around 5 acres regularly and maybe 10 additional acres every other week.
The only couple of things I've noticed on the Ferris that aren't issues, but maybe something they could do better is the placement of the p-brake. The lever is up too close to the steering lever, IMHO. This is super trivial complaint though.
Also, the top of the deck is awfully busy. Lots of bars, belt runs, just looks a bit complicated compared the Outlaw XP. I guess the suspension is the cause of some of that. They also seem to run a two belt setup for the blades. Some reviewer on Youtube said this was a redesign to prevent belt coming off problems they'd had in the past. :confused3: However, I'm willing to overlook these things though for the Vangaurd EFI and the suspension. Can't wait to get one. Just might be awhile. Got any pictures of your 3200?
