Thanks for the detailed answer. I have actually downloaded the Tuff Torq 92 service manual which I found online. Same one you have?
I have TT on my list to call, assuming they are open on Monday (Columbus Day).
Looks like the Simplicity full service manual is $40 on line (shop manual).
In reading through the threads, I also see that some have pointed to problems with the PS (p/n 1725288SM).
This would obviously be a better repair. I am not sure my mechanic put a lot of troubleshooting into my issue.
Is there an easy way to isolate to either 1) hydraulic pump, 2) valve chest, or 3) PS pump?
The current symptoms are no PS, FEL bucket will roll up or down into dump position but VERY slowly. Arm will not lift at all, this was a sudden onset problem ...
Thanks again for the reply... I’ll let you know how this plays out... still in the figuring stuff out mode...
