- Nov 29, 2014
- Threads
- 64
- 24,718
not meaning to sound critical but just about every mower owners manual tells you to remove sticks & other debris from your grass before mowing.
An instruction that is ignored by around 99.99 % of the population.
If you have a lot of them and they are causing you problems then get a yard vacuum and remove them.
Make a well around plants that suffer attack from things like slugs & snails then use them to mulch the plants.
The poo pickers made for collecting horse droppings work really well and are much easier than a strait vacuum.
As sweet gum balls only drop in winter it is a once or twice a season job.
Lots of small units that you tow behind your mower.
Don't try it with a hand held blower - vac as they will jamb the impeller.
We have a lot of trees that drop similar nasties down here.
Put a layer down before you lay your spring mulch will allow the mulch to work so much better.
