john deere115lawn tractor blade hit object now no gas to carb. flywheel key intact. installed new coil, spark plug, air and gas filter. starter working fine. engine cranks but no gas to gas pump. please help
I am a total novice and have no idea what a fuel shutoff solenoid on the carb looks like. would you mind explaining how I can determine if my john deere 115 has one, or where to look for it?Is the a fuel shutoff solenoid on the bottom of the carb bowl?
just out of curiosity
did the engine stop same time you hit object?
the third line should have said I tried to restart and heard a noise from the blade hitting the deck.Thanks lugnut, no, it did not stop after the blade hit the curb and bent the blade which then hit the deck. after disengaging the blade I drove the tractor to the rear of the house. I was not smart enough to check the deck and blade. so I tried to restart and got a heard from the blade hitting the deck. the blade hit the deck with such force that the body of the tractor shook slightly it was then that i finally realized that the blade was hitting the deck. but after changing the blade the tractor would crank but no gas was going into the carb. with help I took of the flywheel and the flywheel key was ok. I followed instructions that came with the coil on installing it. it did no mention timing or matching marks on flywheel with marks on the engine. but I don't think that it calls for timing. even so wouldnt I still get gas. I already put a new fuel pump on. I hope you can hang in there with me I am desperate and got no money for a repair shop. my grass starting to be a jungle
thanks shiftsuper, Tried earlier to respond but I screwed it up, still learning. went online and saw the fuel shutoff solenoid but i am not getting fuel to the carb.
