Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2014
    Posts
    18
    Location
    Minnesota
    Mower
    McCULLOCH MAC 120 Chainsaw
    I am not positive what model this is as the number stickers are gone. Could be a mini also. I just know it is a pain to rebuild carb ad you have to pull the entire motor out of the aluminum housing. I took it apart and cleaned it up and put new gasket kit in carb. Did not remember the needle valve adjusments and it flooded and would not start. I reset the needles to 3/4 on H and 1/2 on L after it sat over night and it started right up. Adjusted the carb and ran good but ran out of gas and then would not start again, just flooded out. Let it sit again and it started right up, adjusted carb ran well for about 2 min then died and would not start again. Frustrating!!
    Any ideas what is going on?
    Thanks
    Happy New Year
  2. #2
    Join Date
    Jul 2013
    Posts
    5,119
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
  3. #3
    Join Date
    Jan 2016
    Posts
    Location
    Alabama
    Mower
    I Don't Own a Mower :(
    Re: McCULLOCH MAC 120 Chainsaw
    Try sparescentral.co.uk, we cover a whole range of chainsaws, I think you will locate the part you need
Similar Threads
  1. Merry Mac Lawn Vac
    By jekjr in forum Commercial & Residential Lawn Mowing
    Last Post: 05-26-2014, 09:26 AM
  2. 3214 mcculloch chainsaw wont prime
    By savitout541 in forum McCulloch Forum
    Last Post: 05-19-2014, 04:31 PM
  3. Mcculloch pro Mac 440vc chainsaw issue
    By man114 in forum Mower & Equipment Operation
    Last Post: 05-18-2014, 08:01 AM
  4. Pro Mac 2035 by McCulloch weed eater bogs down.
    By weedy in forum McCulloch Forum
    Last Post: 04-15-2014, 05:19 PM
  5. McCulloch: Mac 2816 weed wacker NO Spark
    By walkinman in forum McCulloch Forum
    Last Post: 06-21-2011, 06:16 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
