Really hoping to get some cub cadet help here
funnsun34
A frustrated cub cadet owner looking for some help.
I have a cub cadet LT 42, which is probably 10 years old. It was running fine like eight days ago. Yesterday went out to start up to mulch leaves. It seemed like it cranked over or two times and then it stopped. With the key still in the start position and after it stopped turning, I could hear kind of a high-pitched sound. I assume it was the battery so I took it out to take it to the house. Before I put on my charger, I checked it with a multimeter and it was fully charged.
Earlier this year, I had one of the safety switches go bad. It was the one that would shut the motor off when you engage the blades.
I have a feeling it might be another safety switches, causing this issue too.
Any suggestions would be greatly appreciated
If it's a safety switch it will not do anything or make any noise , all safety switches interrupt the circuit to the starter.
If it's making a wining noise , it's a good bet it's your starter
Hello F.,
We need the chassis product label and engine ID label information.
My allotment of wild guesses is running low.
Can't trust a multi meter on batteries as it doesn't load test them. It could be still bad.
And as said need the equipment info as my insight data link from Pluto is down due to AI hacking it.
First 2 things that come to mind is the compression release broke on the camshaft if it has the single cylinder OHV Briggs engine. And second though would be to check for hydrolock due to pulling up a large amount of fuel. Either way remove the spark plug and see if it will crank over. If gas runs out of the spark plug hole, Blow the cylinder out with compressed air, and be very careful about cranking it. Have has more than one ignite from the static discharge of gas being forced out of the spark plug hole at high velocity.
Thanks all for the tips. Earlier this year I replaced the solenoid and the coil. The battery is only a few weeks old. I’ll try a few of those things that you guys mentioned. I do have a John Deere zero term being delivered tomorrow.
Kohler KS540-3011 engine which is the newer 5400 series version of the Courage single.
The high pitch whine is typically the starter struggling to start and slowly being damaged. Kohler Courage is notorious for having starter issues. Kohler 5400 Series is the newer and improved version of the Courage. When you hear the high pitched whine, back off of the key, and try again. Don’t just keep turning the key. Could be loose wiring or corrosion on terminals. Could be a weak battery. Could be a failing compression release mechanism. Could be a weak starter.
