2008 Hustler Super Z Diesel - To repair or wave the white flag
Buxus
Location
Maryland
I have a 2008 Hustler Super Z, 927335. It has a 32 hp Perkins diesel. It has 700 hours on it, was privately owned, and sat in a garage for years – no rust. Just before I purchased it new hydros were installed. I purchased it to have a pre-emissions high torque beast for cutting tallish grass on my property, about 100 hrs per year.
Shortly after purchasing it, it began to overheat after about 30 minutes. I would of course shut down immediately. Local mechanic replaced thermostat and water pump before I realized that one of the two rear fans was not running. It would blow the fuse repeatedly. I am fairly certain this is why it overheats and wish the mechanic had caught it.
While at a different mechanic’s place awaiting a fan the hydraulic pump failed and now the mowing blades don’t spin. Mechanic says the pump is shot, and there are shards of metal in the hydraulic fluid. He said the metal is more than could come from the scoring he sees on the pump. He said he’s not sure if the shards are old from a pre-hydro replacement issue or are new from an ongoing issue. Both wheel motors currently work great.
The mechanic said a new hydraulic pump is $1500, and it’s about $4k total to replace the pump and flush the system, but that 1. he might not get all the metal out of the fluid (tiny bits left in hydros) which could cause problems, B. there still might be an underlying problem that is undiagnosed so hydraulics might fail again.
I love the mower, and I’d like to get it fixed. I’m not going to be able to get something comparable hours and power wise for under $10k, although it might be a bit newer. On the other hand, am I getting in too deep with too much uncertainty? What do you all think? Thanks!540AA4BD-5961-40C1-86BA-270BCC089A7A_1_102_o.jpeg
The pump coming apart was probably the root cause of the motor hydros going bad if they share the same oil ,may not be a filter on that system , not sure but I'd install one going forward . Sounds like you're pretty deep into repairs already but the machine may be worth another 1500 - 4000 seems a bit much imop .
I love the mower, and I’d like to get it fixed. I’m not going to be able to get something comparable hours and power wise for under $10k, although it might be a bit newer. On the other hand, am I getting in too deep with too much uncertainty? What do you all think? Thanks!View attachment 75016
You have an 18 year old zero turn, that would cost $20,000 to buy new. Although Perkins diesel is a great engine, it limits how many shops will and can work on engine. The mechanic saying the new pumps may be damaged by metal shavings in system unable to be completely removed, is a possibility. Paying $4,000 is a huge repair bill and somewhat risky. The hours on machine are low, and the mower looks to be in good shape. There is nothing special about Hustler zero turns. A decent mower made in Kansas and recently bought out. Weigh your pros and cons…
