X125 starting problem
phildunford
My X125 has a weird starting problem. Starter engaged but did not have the power to turn the engine over. It seemed like a flat or dodgy battery - so bought a new one - same problem.
Starter relay looked corroded, so fitted a new OEM one and cleaned up all the terminals and leads in the high current path and crimped on new spades on the low current side. - same problem.
Made up new high current leads, a bit thicker than original. Same problem.
Replaced starter motor (not OEM, but looked decent). Exactly the same problem.
The engine runs fine once it starts. Sometimes it turns over fairly well, sometimes the engine just seems to stall the starter and it gets hot - very inconsistent.
It almost seems that sometimes the engine is very hard to turn over - yet when I turn the 'fan' on top by hand, it seems OK.
No idea where to go from here. Any clever people with bright ideas??
P.S. The deck is not engaged - I can see the drive belt is loose, so there is no load on the engine.
please confirm the understanding:
1.Turns over normally by hand
2. New battery
3. New heavy duty positive and negative cables
4. new starter relay
5. New aftermarket starter
#3 assumes the connections were cleaned, and #2 assumes battery was fully charged.
I would use a volt meter to find where the voltage is being lost. If you have full battery voltage to the new starter then it is bad, try another. If the battery is being pulled down by the starter, try running the starter off it with no load (removed). Could be a bad new battery. Otherwise the volt meter will reveal where the current is being lost. You can also try spinning it with the plugs out to see if changing the load matters.
Hi - It's single cylinder John Deere 4 185 500cc. Which I think was made for JD by Briggs and Stratton. How could valve adjustment cause this please?
When valve lash becomes too much due to wear and tear, the compression relief become less effective. When that happens, the starter has to strain to spin the engine because it is fighting higher than normal cranking compression.
