Seat springs
GrandPaRay
I have a TS 354 Husqvarna. It has rubber bumpers instead of spring on the seat and it is killing my lower back since what I mow is not even. Are there springs that can be used in place of the bumpers? Do you have a part ##? Thanks
Springs won’t really help either. Most riding mowers, and zero turn mowers, ride like lumber wagons unless you have a suspension seat. I am not sure if you can get a suspension seat for this Husqvarna mower, but it is worth looking into. Suspension seats are real game changers when it comes to ride quality and wear and tear on your body.
I have three Dixie Choppers that I mow with and have a suspension seat on one of them a suspension system mounts under the seat that works pretty well When I use the one that doesn't I can really tell it..
thahttps://www.bing.com/shop/topics?q=suspension+system+that+mounts+between+seat+and+frame+of+mowers&FORM=SSAT01t
Depends....There are a version with springs.
Look where two rear bolts on the fender pan meet under the seat. Do they line up with solid areas on the seat pan that springs could sit on?
Why not level the yard out with either sand or rich mix top soil? Then EVERY mower you buy later will be a soft rider.
A modification I have used on several old farm tractors, riders and zero-turn mowers is old automotive engine valve springs. They are stiff but provide a little bit of extra shock absorption. Basically, you remove the old, hardened rubber bumper then use a bolt nut and washer to hold the spring to the mount surface.
Start by checking your tyre pressures - The first "spring" in a wheeled vehicle/equipment, is the tyre wall flexing. Too much pressure and you reduce that flex. As a start point go with the mowers recommended minimum tyre pressure & adjust, if required, from there.
:devilish:
