I am going to take a Honda HRX217VKA from a friend to bring back to life after being completely submerged in flood waters after torrential rains in Columbus Ohio. This happened just a few days ago so there should not be too much of a rust issue with any components to deal with. My plan is to remove all gas and oil, clean everything around the flywheel, remove the carburetor bowl or maybe the carburetor completely and spark plug, inspect, clean and go from there. Of course I will look at the controls and cables too re-lubricate as needed.We'll see how robust these mowers really are if I can resurrect it!
I will update here to share my results.
