If you are RTVing the valve cover clean all oil off, apply RTV, install the cover with finger tight screws, let sit over night without starting the engine, then toque the screw to 65 in-lbs. This gives time for RTV to setup well.Otherwise the cover will leak in short order.
I going to do a little fly fishing tomorrow after I repair my storm door damage as a storm nearly ripped it off the wall. Ripped the safety right out the frame and broke the door latch. Fishing a heck a lot easier than repairing engines.
