Many riding mowers are unstable and tippy on steeper slopes. That’s when a good zero turn is better. In this case, you either can maintain control and it feels acceptable, or it doesn’t.I have a 2026 CC XT1 LT46 and part of my yard has about an 18-degree slope. Is there a safe way to mow this area horizontally, not vertically, using weights, and/or liquid in the rear tires? I do have access to two 42 LBS suitcase weights if those would help.
I used to mow commercially before doing small engine repair. The two zero turn mowers that really hold a hill well are Scag and Ferris. Some were so steep it required going up and down to mow it. Way more that 18 degree slope. More like closer to 45 degrees. Never had a problem with oil starvation in engine or hydro pumps, but something to definitely be aware of.Unless you realy know what you are doing, understand the limitations of your machine (including is it fitted with ROPS) do not risk cross slope mowing or steep up slopes.
Ride on mowers can kill or severely injure you - why take the risk.
There are only a very few ride on mowers, that are specifically design to operate on steep slopes, get one and stay safe.
View attachment 74214View attachment 74215
