Fr730v control panel, throttle linkage and springs
john in ohio
This control panel and linkage is difficult to do correctly if you're new to it. I'm in over my head. It seemed simple when I took it off to clean the carburetor. Now I don't have throttle control. Something is wrong here.
I would ask on here or call Kawasaki and get a shop manual. Look online for a shop manual for your engine.
Next time take pictures of the linkage before messing with the carb.
Did you hook the throttle cable up to the governor/throttle spring slash linkage?
Take a picture showing how you reconnected it. Or even better link a video on here to youtube showing us your issues.
I think I forgot the spring from the governor arm to the control plate to pull the throttle cable. Now that I put it on, the governor surges and the idle will not smooth out. I have a shop manual, it's confusing to me. I'll have to reread and review what I have.
