I purchased early 2000’s x540 with the 54” deck. Second time I used it and the belt came off. I discovered the tensioner pulley arm/double pulley has been monkeyed with. The sequence of washers and bushings were out of order. I have used the JD Parts diagrams to get everything back in order. The tensioner pulley is about 1 1/2” too high. I got a new arm ordered. The spring rubs on the lower deck drive pulley. This is the dumbest design I have ever seen. I have finally figured out how the parts go back in order. Someone has tried to fix this before I got it and now I have to learn the correct way to put it back together. Any help would be appreciated. Thanks
