Husky R120S z turn mower, deck drive belt cost $85, anyone has a diameter for that belt that I can get a generic one for less?
MO MOWING
Apparently no one in at least the last tens years have never bother the measure the belt.
But run PN 580926501 superseded to 584299801 thru your search engine and there lower cost OEM belts out there. The overall cost depends on the shipping.
By doing some cross checking online, the belt size can be fairly easily determined. $85 these days sounds reasonable for an OEM belt, especially if the aftermarket belt is only slightly less in cost.
