This starts just fine but as soon as the choke starts to open it wants to stall. New plugs.
If I hold the choke control full forward (closed position) it runs pretty much ok but as soon as I take my hand off it sarts to open and the machine starts surging like every 2 seconds. Blades running, or blades disengaged the same. And any throttle position less than full tils it stalls. Sounds like fuel starved..??
I'm new to these 2 cyl 4 stroke engines. Anybody have any advice on most likely issue? Oh yeah, I did change the fuel pump over the winter, from Amazon, said it was OEM. I can see fuel flowing in the clear fuel filter.
Georgec
Georgec
