Cold weather starter just spins?
Elkins45
Hello E.,
We specifically need all the information that is stamped into the top of one of the engine rocker/valve covers. If the valve cover has been off, it could have been reinstalled upside down, so the numbers would be on the underside.
Can you see the gear on the top of the starter? If not, the top plastic fan shroud will have to be removed. They are pretty simple to take off.
If it has the black plastic/nylon gear, it may have split in half. I have that happen several times in recent years.
The individual gear can be replaced but it takes some skill and patience.
The gear is under the shroud. It's going to be single digits here for the weekend so if a heat gun doesn't pep it up tomorrow morning then it's going to wait a few days. I have a spare starter I pulled of a scrapped engine but I really suspect the only issue is the cold.
Craftsman Garage
Looks like you have the first starter in the diagram that startech posted. You CAN oil this one, so I would suggest you try that.
The first starter has a nylon gear and I’ll bet it is stripped.
